What pins do I connect to do the ABS paperclip test?
by Red_Calibra » Thu Feb 23, 2006 10:30 am
The topbuzz guide says pins "A" and "K" on the left hand side, which are directly above each other in the diagram.
However, after doing a bit of searching here, I noticed a couple of folk saying that the ECU paperclip test should be carried out using "Pin A and the fourth one along".
What one is correct?
Red_Calibra
by johnny_adidas » Thu Feb 23, 2006 10:33 am
the first 2. thenif they dont work try the other two
johnny_adidas
by RobbieV » Thu Feb 23, 2006 11:49 am
Try this [img]/smile.gif[/img]
<a href="http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm</a>
by Red_Calibra » Thu Feb 23, 2006 12:15 pm
Cheers guys, I'll try the Topbuzz A+K pins first and report back.
Red_Calibra
by Doodley » Thu Mar 02, 2006 9:38 pm
i used that topbuzz link, done it how they say, got code 55 which is faulty abs ecu, changed it and problem solved. good luck
Doodley
Users browsing this forum: No registered users and 48 guests
