click when turning left
by stiofansisland » Sun Apr 30, 2006 1:01 am
best way to describe it is it sounds like it's trying to clik the indecator off when i turn left but it's not the indicator but sounds like it's commingfrom the steering coloum. happens 95% of the time but some times dosent happen?? my guess is the universal joint in the colum?
stiofansisland
by Gixxer » Sun Apr 30, 2006 9:36 am
Yea it probably is, my Vec did that a while ago, I know there's a "how to" on vvoc about it, you loosen the bolt's off and re tighten but torque them or if that if that doesn't work then it's a new joint, there not that expensive though.
Dont know if the Cally's the same be it might similar...hope that helps.
<a href="http://www.vvoc.com/forum/showthread.php?t=35986" target="_blank">http://www.vvoc.com/forum/showthread.php?t=35986</a>
Gixxer
by stiofansisland » Mon May 01, 2006 5:16 pm
cherz r2d2, any one know of a how 2 for a cally or had a similar problem?
cherz, steven
stiofansisland
