how low.....
by philangel » Sat May 01, 2004 6:14 pm
can you drop a cally before you need to start major changes to camber angles and any other suspension settings?
philangel
by Dan Willis » Sat May 01, 2004 6:49 pm
Well by lowering it all you'll be changing the suspension completely I'd hope.
Camber changes should really be done with any drop.
Dan
by DAN » Sun May 02, 2004 1:05 am
Moved it here mate, you may get a better response
Thanks [img]/wink.gif[/img]
DAN
New Wheels
by gran » Sun May 02, 2004 12:54 pm
run a -35mm drop for a couple of months then check your front tyres!
dan would have a better idea, he was running -60mm
gran
by brocklanders25 » Sun May 02, 2004 1:10 pm
i've dropped mine 40mm, the fronts ok but the rear camber is way out, tyres have lasted about 6000 miles so far though so its not as bad as some make out, cambers good isn't it-look at touring cars for gods sake!!! [img]/biggrin.gif[/img] [img]/laugh.gif[/img] [img]/biggrin.gif[/img]
brocklanders25
