Camber questions
Camber questions
Right some more questions, god i hate when i find problems as it just means, im gona be down money for the next while. knew the camber was off but when changing the rear brakes i noticed the inner tyre of one side has really bad internal wear and the other was still ok.
when i changed my front tyres this time last year, they were wore away completely on the inner side of the tyre on both sides. (still not showing major wear due to my mileage)
My cally is lowered 60mm and running 18s. question is, even if i was to get a camber kit, its not gona completely sort the problem at that much drop is it?
and as i only do roughly 3k miles a year, is it a really worthwhile as the kits are not the cheapest
ps i know fatz has done a how to but my drop is a lot more than on the example, plus i reckon i wouldnt be able to manage it.
johnny_adidas
get two 'kits', for both the inner and outer bushes on the rear wishbones..
or try getting a k-mac rear kit, theirs seems a lot better than other kits i've seen.. i have the powerflex eccentric bushes, i had to make a special tool in order to actually set it up..
and as i said, try running big toe in on the rears(camber kits also affect rear toe so you can adjust it too..). i heard it helps when running high camber..
BlackKnight
