Goodridge braided hoses
I have got standard brakes and I can't afford new ones so was wondering if the goodridge stainless steel braided brakes hose kit would help improve braking at all when using standard brakes?
thanks
Chris
thanks
Chris
christaylor
dot 4 will soak up water dot 5.1 is silicone based and will repel water
dot4 normal cheap brake fluid
dot5 is aimed at storing cars
dot 5.1 has the same spec as dot4 but is silicone based
you will have a slight improvement in pedal feel and braking performance as more of your pedal pressure is being turned into braking pressure
dj_smurph
well you learn something new every day.knew there was something bout dot5 and water (pooling). u gota just love the net, beats trawling through books anyday
<a href="http://www.ducatimonster.org/faq/faq_brake_fluid.html" target="_blank">http://www.ducatimonster.org/faq/faq_brake_fluid.html</a>
johnny_adidas
