replacing the Anti-Roll bar drop links. How easy?
Gonna have to do this soon. How easy a job did you find it and are all Calibras using the same part?
jaybv6
<!--QuoteBegin-jaybv6+--><div class='quotetop'>(jaybv6)</div><div class='quotemain'><!--QuoteEBegin-->how about 93/94. Do they use the same part?<!--QuoteEnd--></div><!--QuoteEEnd-->
Not sure, this is the one that fits mine
<a href="http://cgi.ebay.co.uk/ANTI-ROLL-BAR-DROP-LINK-FRONT-ASTRA-CAVALIER-CALIBRA_W0QQitemZ4622835596QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/ANTI-ROLL-BAR-DROP-L...1QQcmdZViewItem</a>
I'm pretty sure they changed over to the new ones in 1995. The old 'push on' (if only it was that easy) ones come in a two sizes, but I'm pretty sure you'll need the 22mm. Phone vauxhall parts to confirm it.
It really helps if you put them in hot water for a few minutes to shrink the rubber bush and then coat with ****loads of washing up liquid and twist on.
To get the old ones off, use a hacksaw to cut all the way through it then break it off. Sand all the rust and crud from the anti roll bar before you fit the new one.
dan1w
