Changing springs
Changing springs
by Phil » Mon Jun 26, 2006 11:13 am
Is there a guide about for changing the springs on the cally?
Do I NEED to use spring compressors?
Thanks.
Phil
by nigescalli » Mon Jun 26, 2006 11:26 am
<!--QuoteBegin-Phil+--><div class='quotetop'>(Phil)</div><div class='quotemain'><!--QuoteEBegin-->Is there a guide about for changing the springs on the cally?
Thanks.<!--QuoteEnd--></div><!--QuoteEEnd-->clamps only needed on the fronts mate remove complete leg clamp spring down and remove rear ones are easy jack up car remove bottom bolt from shocker force wheel down and pull out cheers nige
nigescalli
by Phil » Mon Jun 26, 2006 12:09 pm
Wow - you make it sound so easy!!!!
Add in a few solid bolts and stuff, and that'll be more what I get no doubt [img]/wink.gif[/img]
Phil
