Wheel rubbing
Wheel rubbing
Amateur question but......
and please excuse my ignorance..... i'm learning slowly.....
my wheel is making a rubbing noise as it goes round. Its the caliper part rubbing on the disc......
what can I do?
what can I do?
hormonedmonkey
check the shield first as its the quickest thing to check. then check youy pads.
metallic whirring sounds like your shield though. it would be kind of a high pitch whirr.
completely worn pads would be a grinding dull kind of noise. new pads and ones which are just coming to the end of the life (ie informing you its nearly time to change them) can make a high pitched squeel.
also is it back or front?
johnny_adidas
