Tracking
Tracking
Hi all , were can i get the tracking checked on a lowered cally, had the balancing done but its still pulling to the left, crapfit/national wont touch it cause its lowered, so i need to find somewere in kent, i am in dover if any one can help.
Tia
Rob.
Tia
Rob.
Movie-Torrentz the Home of Quality Movie, Bluray and TVtorrentz
Pop over the river to Elite they will be able to do it.
<a href="http://www.elitedirect.com/" target="_blank">http://www.elitedirect.com/</a>
@morphsis, try sva imports m8 between dover and folkestone by the beefeater on the old A20, come through the roundhill tunnels heading for dover off M20 take the signs for dover and capel le ferne, take 1st exit at small roundabout and follow road for abt 1-2miles and it on the left m8.
wheels always center themselves even with bad tracking. if one wheel is 5mm toe out and the other is 1mm toe out they will center while driving to 3mm toe out both sides and your steering wheel will simply not sit centered but the car will still go straight.
point being - pulling to one side(especially if it's always the same side) usually means bent struts/wishbones or subframe/chassis damage.
BlackKnight
Morphosis
