something has snapped
by Cozy » Thu Aug 03, 2006 5:56 pm
right, reversed out of work on full lock, and something has deffo snapped, heard a metalic crack, so had a quick look and couldn't see anything so i drove it home and there is deffo something rattling about on the front passenger side and it happens going over bumps etc, anyone got any idea what it could be and what to check to see what it is, probably the cv joint i reckon as it has been knocking slightly on full lock on reverse for the past couple of months and today something has snapped
so what could it be, anti roll bar, cv joint wishbone etc
any help appreciated
Cozy
by tobys73 » Thu Aug 03, 2006 6:49 pm
if it rattles going over bumps i would say the roll bar drop link has snaped
tobys73
by mickeyboy » Thu Aug 03, 2006 7:05 pm
<!--QuoteBegin-tobys73+--><div class='quotetop'>(tobys73)</div><div class='quotemain'><!--QuoteEBegin-->if it rattles going over bumps i would say the roll bar drop link has snaped<!--QuoteEnd--></div><!--QuoteEEnd-->yep i would say that? to happen to me and it was roll bar drop link matey
mickeyboy
by BlackKnight » Fri Aug 04, 2006 7:42 am
mine started rattling/grinding over bumps yesterday too.. on the right side.. climbing onto speedbumps and falling off them usually causes the sound. it is somewhat similar to tire scrub onto wheel arch at low speeds.
i've replaced the right anti-roll bar link 4 months ago. if it's broken again i'll defo be looking at uprating them somehow because this is ridiculous, i can't go replacing them every 6 months. im afraid to think what will happen if i decide to install a stiffer anti-roll bar - they'd be snapping every 5 mins.
i dont remember that i had this problem on my old turbo and i use to drive it like a nutter.
are there any differences between models regarding the issue? i presume some have stiffer antiroll bars and i know there's some difference in thickness of something(22mm/24mm) - guessing it's the thickness of the anti-roll bar?
BlackKnight
by Tim2001 » Fri Aug 04, 2006 7:44 am
If the cv joint had snapped you would not have been driving home. Drop links as suggested above.
Tim2001
by Cozy » Fri Aug 04, 2006 8:29 am
Yeah think it is then, it only does it over bumps and it sounds like something is flapping about i'll have a check on it today, seems it is pointing to that, sounds like its attached one side then flapping about on the other side going over bumps, are they cheap to replace then and whats it called the anti roll bar drop link
cheers for the help guys
Cozy
by tobys73 » Fri Aug 04, 2006 9:23 am
yip thats what they r called will cost you between £5-9 depending where u get them and which one you need but there are 2 sizes as you have a v6 it will be the larger one 22mm IIRC
have a look first though and mak sure what type you need
one like this
<a href="http://cgi.ebay.co.uk/anti-roll-link-bar-astra-cavalier-calibra-BRAND-NEW_W0QQitemZ130011285438QQihZ003QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/anti-roll-link-bar-a...1QQcmdZViewItem</a>
or one like this
<a href="http://cgi.ebay.co.uk/anti-roll-link-bar-astra-cavalier-calibra-vectra_W0QQitemZ130011285471QQihZ003QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/anti-roll-link-bar-a...1QQcmdZViewItem</a>
will prob be the first one though and should be cheaper from a motor factor like TMS
tobys73
by johnny_adidas » Fri Aug 04, 2006 9:28 am
they are fairly easy to change. im almost certain if you look at the wishbone how to, it explains how to change it. its in haynes anyway. u should be able to see it if u look through your wheels so u can check if its that that has actually snapped. does sound like it. it sits on top of the wishbone near the outer edge.
johnny_adidas
by Cozy » Fri Aug 04, 2006 9:36 am
thanks alot lads, right will have a look at lunchtime, glad they aren't expensive as i'm a bit skint at mo, is it worth it to do both sides while i'm at it or just replace the broken one then
Cozy
by johnny_adidas » Fri Aug 04, 2006 9:44 am
suppose its more about your own piece of mind than anything else. if your skint, just do one for now, its not critical u do both at the same time.
johnny_adidas
by Cozy » Fri Aug 04, 2006 9:59 am
cheers, will do the one side and see how i get on first, then i may do the other side, cheers johnny and all will let u know how i get on, i think i could stretch to another £6 -£8 for the other side too but will see how hard it is to replace first but doesn't seem to be much of a job so will give it a go over the weekend
thanks again lads
rep points left thanks
Cozy
by johnny_adidas » Fri Aug 04, 2006 10:12 am
just remembered doing mine now and swearing alot while hacksawing through it with a blunt hacksaw and the coont of job to get it back on properly. have a tub of butter or grease to hand also as it'll make fitting the new one a lot easier. here's a full how to.
<a href="http://www.vauxhallownersnetwork.co.uk/showthread.php?t=4720" target="_blank">http://www.vauxhallownersnetwork.co.uk/showthread.php?t=4720</a>
johnny_adidas
by Cozy » Fri Aug 04, 2006 10:22 am
are the later models easier to get off and replace as i heard somewhere on here that the earlier models are a hacksaw off job and the later ones are easier to get off without using hacksaw etc,
Cozy
by johnny_adidas » Fri Aug 04, 2006 10:45 am
oh thats right, yours are the bolt on later type, Lucky %£@%$^*
johnny_adidas
by Cozy » Fri Aug 04, 2006 10:55 am
<!--QuoteBegin-johnny_adidas+--><div class='quotetop'>(johnny_adidas)</div><div class='quotemain'><!--QuoteEBegin-->oh thats right, yours are the bolt on later type, Lucky [email]"%£@%$^*"[/email]<!--QuoteEnd--></div><!--QuoteEEnd-->
Nice one, will probably do both sides then, so i just take the wheel off, then unbolt the broken one and bolt on new one minter
Cozy
