What rear discs have I got?
by Phil » Wed Aug 30, 2006 10:04 am
Just in the process of buying some rear discs and they have asked me to take a photo of them so that they can tell what type they are???
I can't wait though and was hoping to tell them via email. They said there are 3 options....? Interestingly they said the same when I went to a motor factor, different sizes for the 8v / 16v available.
So, my car is a 1991 2.0L 8V - built in drum brakes on the rears for the handbrake.
Phil
by WillsToy » Wed Aug 30, 2006 10:21 am
Brake Sizes
Front : 10.1in dia ventilated disc brakes with floating calipers. (8v / 16v)
Front : 11.2in dia ventilated disc brakes with floating calipers. (V6 / Turbo)
Rear : 10.2in dia disc brakes with fixed calipers (8v / 16v)
Rear : 10.6in dia disc brakes with fixed calipers (16v 4x4 / V6 / Turbo)
Taken from the buyers guide in the quide/articales section
I had thought the only main difference was that the V6 and Turbo had bigger brakes and 5 hole stud pattern.
Would have to check my haynes at home to be certain
Might be able to help you out with the door strip as i have 2 spare doors in the garage that i just rob for bits.
Will
WillsToy
by Phil » Wed Aug 30, 2006 10:55 am
Hi Will,
Well, the company got back to me, I can understand their position. They want to be certain what type it is, as they say Vauxhall had a habbit of fitting whatever was on the shelf at the time. - I know this to be true, as the front wheels had to have part of the hub grinded off as they stuck out further than they're supposed too.
PM sent regarding the rub strips.
Phil
