anti roll bar link help
by Cozy » Sun Sep 03, 2006 1:03 pm
taken wheel off looking to replace the anti roll bar link but after having a look it seems to be fine, so i am sumwhat puzzled as to what the noise is then it is a sort of metalic noise like something is rattleing about going over speed humps etc and the most obvious answer would of been the anti roll bar link
here are a couple of pics of the existing anti roll bar link does this look ok to everyone as there doesn't seem to be any play there, all stiff and tight and it doesn't look like it has snapped, where do they usually snap on the threaded bit
any ideas anyone, have looked at the other bits and everything seems fine and its deffo on passenger side
Cozy
by EY » Sun Sep 03, 2006 1:10 pm
I would check the condition of the other two wishbone bushes, particularly the rear one as they do lots of flexing.
by MJ » Sun Sep 03, 2006 1:40 pm
the pigtail broken off the coil spring rattling about maybe?
MJ
by Cozy » Tue Sep 05, 2006 4:07 pm
just got it up on the ramps and had a look underneath, doesn't look like the bushes have snapped or anything like that, there was a little movement in the passenger side strut on the turret in the engine bay so will tighten that up tonight and see if it's that but i can't see it being that, failing that it could be the caliper but i doubt that either, have checked both anti roll bar links and they are tight with no movement so will give the strut a tighten tonight and see if that resolves it if not i'm at a loss as to what it is
something has deffo snapped as when it did it i was reversing on full lock and i heard something metallic snap i think anyway, oh well will have to have another look if it isn't that
Cozy
by MJ » Tue Sep 05, 2006 4:17 pm
could be in the CV joint, the metal doobrey (technical term!) that holds the balls in place
MJ
by MJ » Tue Sep 05, 2006 4:18 pm
or ..... if you breaked quite hard it might just be movement on the caliper as its designed more to take breaking force the other way
MJ
by Cozy » Tue Sep 05, 2006 4:31 pm
i will have a look at the caliper tonight, don't think its a broken spring as it looks ok and it bounces fine, just that it did it on full lock while i was reversing and had been having a bit of a clunk round that area (while reversing on full lock) before i heard something snap then its a rattling metal sound over bumps etc, getting me stumped now as the obvious would of been the anti roll bar link but both are intact
hmmmm
Cozy
by dreamdim » Tue Sep 05, 2006 8:46 pm
<!--QuoteBegin-Cozy+--><div class='quotetop'>(Cozy)</div><div class='quotemain'><!--QuoteEBegin-->i will have a look at the caliper tonight, don't think its a broken spring as it looks ok and it bounces fine, just that it did it on full lock while i was reversing and had been having a bit of a clunk round that area (while reversing on full lock) before i heard something snap then its a rattling metal sound over bumps etc, getting me stumped now as the obvious would of been the anti roll bar link but both are intact
hmmmm<!--QuoteEnd--></div><!--QuoteEEnd-->
<!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Times New Roman--><span style="font-family:Times New Roman"><!--/fonto-->I could hear a <!--coloro:black--><span style="color:black"><!--/coloro-->rattling metal sound going <!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--><!--coloro:black--><span style="color:black"><!--/coloro--><!--fonto:Verdana--><span style="font-family:Verdana"><!--/fonto-->over bumps <!--fontc--></span><!--/fontc--><!--colorc--></span><!--/colorc--><!--coloro:black--><span style="color:black"><!--/coloro--><!--fonto:Times New Roman--><span style="font-family:Times New Roman"><!--/fonto--><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->so I took the wheel off and I found out <!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--><!--colorc--></span><!--/colorc--><!--coloro:black--><span style="color:black"><!--/coloro--><!--fonto:Verdana--><span style="font-family:Verdana"><!--/fonto-->anti roll bar link has been snapped…so I replaced it but in reverse gear it still makes that noise but not all the time. So it could be CV joint or the way I put new anti roll bar link hope it helps<!--fontc--></span><!--/fontc--><!--colorc--></span><!--/colorc-->
dreamdim
by johnny_adidas » Wed Sep 06, 2006 11:15 am
did you check the tie rod ends? also could be your wheel bearing. try jacking the car up and tugging at the wheel
johnny_adidas
similar prob
by ash_pearce » Wed Sep 06, 2006 7:08 pm
sorry to hijack your thread! but..
one of my links has snapped and the bushes are stuff aswell is it best to replace the whole arm or just the bushes and link, the arm looks fine with hardly any rust. where would be the best place to buy, price etc? thanks:)
ash_pearce
