Dropping H Frame-what nut sizes....-SOLVED!
by Hotrod » Sun May 16, 2004 6:07 pm
I'm in the middle of dropping the H frame and need to undo the driveshaft nut, what size is it? this also needs to be a deep socket too.
Lower balljoint-what size is the nut? seems to be 18mm? bit odd :?
Once I've got them cracked I can look at dropping the frame, any other nasties in there?
I need to get that off to change engines :roll:
Thanks in advance [img]/biggrin.gif[/img]
Couldn't wait for you guys, measured them and bought the tools :roll:
Hotrod
