help needed with a bit of work on my car
by BazV6er » Wed Oct 04, 2006 11:55 pm
what do i need to get if my lower balljoint has gone ?would it be better for me to buy two wishbones structures as well as two new anti roll bar droplinks...
by RobbieV » Wed Oct 04, 2006 11:59 pm
<!--QuoteBegin-Baz16v+--><div class='quotetop'>(Baz16v)</div><div class='quotemain'><!--QuoteEBegin-->what do i need to get if my lower balljoint has gone ?would it be better for me to buy two wishbones structures as well as two new anti roll bar droplinks...<!--QuoteEnd--></div><!--QuoteEEnd-->
I would buy 2 wishbones and new drop links, once fitted makes a big difference [img]/smile.gif[/img]
by BazV6er » Thu Oct 05, 2006 12:08 am
is the ball joint fitted into the wishbones rob or do you have to buy them separate
by Rusty_CallyT » Thu Oct 05, 2006 12:47 am
built in afaik
Rusty_CallyT
by BazV6er » Thu Oct 05, 2006 3:02 am
ok so its built into the wishbone ,ok cheers adam
by callyben » Thu Oct 05, 2006 6:00 pm
they are riveted in. but they can be removed by drilling out the rivets and fitting the the new balljoints with bolts. it would be a lot easier to fit new lower arms and droplinks.
the rear bushes on both sides on mine have gone. but i cant decide wether to upgrade to powerfelx bushes or buy new lowerarms??
callyben
by Chavtastic » Thu Oct 05, 2006 7:14 pm
Should be about £18 for a pair of decent wishbones, and about a tenner for the ARB links (which are normally broken) [img]/laugh.gif[/img]
by BazV6er » Thu Oct 05, 2006 7:16 pm
well last year ben i paid about £4 for each ARB link
by mickeyboy » Thu Oct 05, 2006 7:17 pm
here you go matey they come with the wish bonesi got mine of ebay cost me 34.87 complent matey and yes there easy to fit
mickeyboy
by BazV6er » Thu Oct 05, 2006 7:19 pm
well im gonna have a go at these with the fiancees dad ,are they easy to replace?
im not great at doing mechanical things ,i was gonna take it to a garage but i think they would charge me the earth
by mickeyboy » Thu Oct 05, 2006 7:30 pm
<!--QuoteBegin-Baz16v+--><div class='quotetop'>(Baz16v)</div><div class='quotemain'><!--QuoteEBegin-->well im gonna have a go at these with the fiancees dad ,are they easy to replace?
im not great at doing mechanical things ,i was gonna take it to a garage but i think they would charge me the earth<!--QuoteEnd--></div><!--QuoteEEnd-->yes matey there easy to fit should take about 35 to 45 min each side and you need a torquewrench matey to do them back up and there 3 setting for them
mickeyboy
by Chavtastic » Fri Oct 06, 2006 8:49 am
You won't struggle if you take your time. Nothing is fiddly at all.
Basically
jack the car up on axle stands.
wheel off
undo the bottom ball joint (easy)
undo the anti roll bar link (easy)
use a balljoint splitter to split the balljoint (easy if you can use a hammer lol)
then just undo the x2 big bolts holding the wishbone into the body/subframe (easy)
pull the wishbone out! (simple!)
by mickeyboy » Fri Oct 06, 2006 6:39 pm
if you need a hand bring it down matey ill do them for you?
mickeyboy
by Rusty_CallyT » Fri Oct 06, 2006 6:59 pm
how do you get a torque wrench on the balljoint nut with the driveshaft in the way?
Rusty_CallyT
by v6calibra » Fri Oct 06, 2006 11:00 pm
i always opt for drilling them off and fit new ones as they come with bolts
v6calibra
