wheels
wheels
by mickeyboy » Sat Oct 21, 2006 2:25 pm
right got a small prob i now have these wheels on my car but it just dont handle right.ie it wanders and steering wheel seams to be really light?and i was thinking the traking mite need ajusting.?they are team dynamics rim width 7.5j and are 17in the offset is 38
mickeyboy
by wilkybar-kid » Sat Oct 21, 2006 2:43 pm
Just one of the problems with fitting bigger wheels.
wilkybar-kid
by mickeyboy » Wed Oct 25, 2006 9:32 pm
<!--QuoteBegin-wilkybar-kid+--><div class='quotetop'>(wilkybar-kid)</div><div class='quotemain'><!--QuoteEBegin-->Just one of the problems with fitting bigger wheels.<!--QuoteEnd--></div><!--QuoteEEnd-->no something is wrong it cant be just that the car does not feel safe to drive
mickeyboy
by callyben » Thu Oct 26, 2006 12:36 am
its cos if the offset is wrong. you have altered the geometry of the steering to much. i noticed it on cornishtaz's car. it felt the same as you described and that was 38 offset.
callyben
by mickeyboy » Thu Oct 26, 2006 7:26 pm
<!--QuoteBegin-callyben+--><div class='quotetop'>(callyben)</div><div class='quotemain'><!--QuoteEBegin-->its cos if the offset is wrong. you have altered the geometry of the steering to much. i noticed it on cornishtaz's car. it felt the same as you described and that was 38 offset.<!--QuoteEnd--></div><!--QuoteEEnd-->so wot do i need to do sorry abit thick?
mickeyboy
by Chavtastic » Thu Oct 26, 2006 7:54 pm
Put some normal sized wheels back on, or continue to think you know better than Vauxhall engineers [img]/wink.gif[/img]
by Animal » Thu Oct 26, 2006 8:34 pm
Or just get some wheels with a closer to 49 offset.
by Animal » Thu Oct 26, 2006 8:35 pm
<!--QuoteBegin-Chavtastic+--><div class='quotetop'>(Chavtastic)</div><div class='quotemain'><!--QuoteEBegin-->Put some normal sized wheels back on, or continue to think you know better than Vauxhall engineers [img]/wink.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
*cough cough* how big are your wheels?? :icon_nod: 16"?? [img]/wink.gif[/img]
by Chavtastic » Thu Oct 26, 2006 8:47 pm
I've explained before why I have 17" wheels. It's because of the brakes I am going to be running! I have no choice.
by callyben » Fri Oct 27, 2006 1:16 am
<!--QuoteBegin-mickeyboy+--><div class='quotetop'>(mickeyboy)</div><div class='quotemain'><!--QuoteEBegin-->so wot do i need to do sorry abit thick?<!--QuoteEnd--></div><!--QuoteEEnd-->
buy wheels that fit properly
callyben
by Mondo » Fri Oct 27, 2006 9:06 am
So what will ET35 wheels do on a Calibra then...?
Mondo
by callyben » Fri Oct 27, 2006 9:21 am
stick out of the arches. dont buy them for a calibra. you will have major issues espescially if lowered.
callyben
by Mondo » Fri Oct 27, 2006 9:28 am
I've got them on the car now and they seem fine - the fronts are close to the edge of the arch and the rears sit nicely... it's not lowered yet but it doesn't look as if there'd be any problems...
Mondo
by callyben » Fri Oct 27, 2006 9:51 am
cornishtaz has problems with catching on 42mm offset (et 42) and its lowered.
callyben
by Mondo » Fri Oct 27, 2006 10:04 am
I'll have to keep an eye on it then. Cheers for the heads up!
Mondo
