Traction control light still on?
Finally managed to get my ABS sensor swapped and althought the ABS is now working better than it ever was, the TC light is still coming on which was one of the problems that I had mentioned quite a while back. The ECU does it's check upon starting the car and all looks good. However, once I head off the TC light comes on. Hoped it wasn't going to be anything major but just in case I've managed to get hold of a whole TC housing and also a TC ecu. Hope it might be just a case of whipping one out and replacing it or at the most both? Any suggestions would come as a great help?
These links might offer some info for you [img]/smile.gif[/img]
<a href="http://www.v6calibra.com/tc/v6calibra_TC_system.htm" target="_blank">http://www.v6calibra.com/tc/v6calibra_TC_system.htm</a>
<a href="http://www.v6calibra.com/abs/v6calibra_abs_system.htm" target="_blank">http://www.v6calibra.com/abs/v6calibra_abs_system.htm</a>
Cheers for that Robbie, that's what gave me the idea of obtaining another ECU and TC motor. Had an in depth look at the website and was hoping that there would have been an easy solution to my prob. Looks like it's going to be trial and error?
My TC does the same as yours :frown:
Ive got a spare TC motor which i stripped down and cleaned and when i get round to it will change it over to see if it makes any difference.
If you want to strip it down here's a link to show you how :
<a href="http://www.cavweb-forums.co.uk/showthread.php?t=23163" target="_blank">http://www.cavweb-forums.co.uk/showthread.php?t=23163</a>
Same as mine, 2/3 secs after pulling away. Mechanic looked at rings and they were in good shape.
Robbie, was looking into stripping the TC motor at some stage. The V6 website states that the brushes are the likely part to degrade and by replacing them it sort of gives the motor a new lease of life? Well, tried emailing both the V6 admin and also the site that they suggest getting the brushes from to get the part no. if any and both have declined to reply. Will try giving the brush suppliers a call and see what they say?
<!--QuoteBegin-ecosseM+--><div class='quotetop'>(ecosseM)</div><div class='quotemain'><!--QuoteEBegin-->does it start about 30/40mph? my old v6 had a t/c prob and it turned out that the abs ring was split, and when was getting upto some speeds it was opening up and sending false signal to t/c ecu<!--QuoteEnd--></div><!--QuoteEEnd-->
Would this not cause the ABS light to come on as well?
<!--QuoteBegin-baby9bird+--><div class='quotetop'>(baby9bird)</div><div class='quotemain'><!--QuoteEBegin-->One of my alloys leaks changed it from front to back after about a week no t/c light!<!--QuoteEnd--></div><!--QuoteEEnd-->
Now you've confused me (which ain't hard at best of times), leaks what? (air?)
I think I'll give the air thing a go before I plunge headfirst into dismantling the TC motor but I do a regular tyre pressure check so might not be that. Is there a definative period of time where the TC needs to settle down after fitting new tyres? Read that even new tyres can cause the TC light to show up. The tyres have been on for a while but the abs was causing the main problem and now that's fixed will the TC sort itself out?
From V6calibra.com
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Under certain conditions where there is a difference between the rolling diameters of the front wheels the TC may activate or may generate a TC fault light. This can happen where you have one new and one worn tyre, a puncture - travelling on the space-saver wheel or even just after fitting 4 new tyres. To minimise this effect the <!--coloro:#000080--><span style="color:#000080"><!--/coloro-->TC ECU features a 'learn' function<!--colorc--></span><!--/colorc--> to compensate under these conditions. The learning adjustment is only carried out under specific circumstances and may take some time to correctly set the adjustment factor. You can help out by providing the correct driving condition for TC 'learning' :<!--fontc--></span><!--/fontc-->
- <!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#800000--><span style="color:#800000"><!--/coloro-->Ensure all tyres are set to correct pressures <!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->(V6 = 34 psi front / 31.5 psi rear)<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--></li>
- <!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#800000--><span style="color:#800000"><!--/coloro-->Accelerate to between <!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#0000ff--><span style="color:#0000ff"><!--/coloro-->62<!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#800000--><span style="color:#800000"><!--/coloro--> and <!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#0000ff--><span style="color:#0000ff"><!--/coloro-->74 mph<!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></li>
- <!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#800000--><span style="color:#800000"><!--/coloro-->Allow speed to bleed off and <!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#ff0000--><span style="color:#ff0000"><!--/coloro-->DO NOT<!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#800000--><span style="color:#800000"><!--/coloro--> touch the accelerator or brake<!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></li>
- <!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#800000--><span style="color:#800000"><!--/coloro-->Continue to allow speed to bleed off until the speed drops below <!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#008000--><span style="color:#008000"><!--/coloro-->43 mph<!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></li>
- <!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#800000--><span style="color:#800000"><!--/coloro-->Repeat up to 5 times for application of full TC tyre adjustment factor<!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></li>
