Camber Adjustment
Camber Adjustment
I'm looking for rear camber adjustment bushes for my 95 turbo,
Regal have quoted £180 for the four bush set which i think is expensive, anybody know where to find them cheaper ?
Also looking for a front adjustment kit but i'm struggling.
The car is lowered 40mm.
Thanks g17egg
Thanks g17egg
g17egg
You won't get the "good" kit any cheaper really.
but you can get the cheap kits cheaply. there is the vaux irmisher(sp) one avaliable direct from vaux, and the powerflex one, avaliable from powerflex dealers, neither is any good really in comparison to the one you're on about.
<!--QuoteBegin-g17egg+--><div class='quotetop'>(g17egg)</div><div class='quotemain'><!--QuoteEBegin-->I've already got the powerflex ones fitted, but they're not much good. I'll just go for the regal ones i think.
Does slotting the holes work well? I've never heard of anyone trying it
greg<!--QuoteEnd--></div><!--QuoteEEnd-->
It works ok if you can be bothered tightening it up, measuring it, loosening it off, tapping it along a bit, tightening it up, measuring it etc.
People will tell you its a bodge and unsafe as potentially it can move, but TBH thats a nonsense, the clamping force is more than enough to hold it in place, the only way it would move is if you have a very severe accident, and the arm would bend first!
chip
<!--QuoteBegin-g17egg+--><div class='quotetop'>(g17egg)</div><div class='quotemain'><!--QuoteEBegin-->Just phoned the guy thats setting the suspension, he's cool about me slotting the holes but said i'd need to slot them at least 10mm maybe 15 with the being dropped 40mm.
Does that sound about right ?<!--QuoteEnd--></div><!--QuoteEEnd-->
No, that doesnt sound right, I would expect more like 5mm as you WANT some static negative on the front anyway to aid cornering.
As i said though, its a trial and error process.
chip
Users browsing this forum: Bing [Bot] and 4 guests
