One way Valves!!!
One way Valves!!!
by Shrubie » Wed Dec 20, 2006 8:13 pm
My leaking brake hose turned out to be not the hose but the one way pressure valve that the rear hose connects too!! Has anyone had this fault with thier cally?
I went along to vauxhall and depending on what chassie you have its either £65 or £180 to replace!!! For somthing thats not much bigger than an AA battery!!!
Luckly after taking it apart and hermatiting the thread and puttin it back together it seems to be holding but CHRIST!, thats alot of money!!!!!
Shrubie
by a_c » Wed Dec 20, 2006 8:30 pm
calibras are being broke left right n centre (surprise surprise) so it wont be hard to obtain a valve from one of them calis have a look around ebay & migweb, also clubcalibra.com
a_c
by Shrubie » Wed Dec 20, 2006 8:41 pm
Definatly the way to go, its fine at the mo but gonna leave it till saturday and check for leaks then, if its holding great if its not ill replace it!!!
Shrubie
by Rusty_CallyT » Thu Dec 21, 2006 12:32 am
its a brake balance valve, not a one way valve, just FYI
Rusty_CallyT
by Rusty_CallyT » Thu Dec 21, 2006 12:53 am
remembering that brake systems are designed with failure in mind and it would take something pretty catastrophic for all the brakes to be non functional
Rusty_CallyT
by Leigh » Thu Dec 21, 2006 1:47 am
I had a leaking/fault one several months ago and it was £50+ for a pair of replacements [img]/sad.gif[/img]
My mechanic said at the time that if it had failed it would not have been good! I can't remember if he said it would have locked the brakes, or they would have failed..
Leigh
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 11 guests
