Intermitent Knocking?
Coming home from work the other night and i hit a huge pot hole in the road,i thought i had definatly kerbed my wheel as this hole was huge and it threw the car almost in the air,stopped the car and had a look and the wheel was fine,but now im getting this intermitent knocking coming from the front of the car,it can happen at any speed over 50,i drove to work today and it was fine,so its not happening all the time just every now and then? Any ideas what it could be?
Fostersice17
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->Ball joint
Bottom arm bush
Bolts come a bit loose on the bottom arm
anti roll bar bush
wheel bearing<!--QuoteEnd--></div><!--QuoteEEnd-->
What he said :icon_mrgr
Bottom arm bush
anti roll bar bush
any bit on the suspension or steering that is worn enough to knock ..is dangerous to a degree. depends how worn its is..and don't forget any suspension or braking parts should be changed as a pair ..If it was me I would get two arms and replace them. If the pothole was that big its also more likely to have knocked your tracking out I would also expect the wheel bearing to go soon as well..but its all down to how thick your wallet is ..me I would just change the lot at same time, work out cheaper in the end
Fostersice17
Mine has been knocking for a while. I changed the topmount that was guilty for some of it. But there are still knocks, next I will change the roll bar bushes, then wishbones (fitting poly bushes) Have new shocks to go in too...that should do the trick. Lower arms knock when braking and accelerating - that i know for certain.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
Users browsing this forum: Bing [Bot] and 7 guests
