Would these brakes fit?
I was told golf/corrado vr6 brakes would fit the 2.0 16v Redtop calibra. I need to replace my brakes so may aswell upgrade while I'm at it..
So, would these fit?
<a href="http://cgi.ebay.co.uk/1995-MK3-GOLF-CORRADO-VR6-280MM-FRONT-BRAKE-CALIPERS_W0QQitemZ140084102059QQihZ004QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item140084102059" target="_blank">http://cgi.ebay.co.uk/1995-MK3-GOLF-CORRAD...tem140084102059</a>
Obviously I'd need discs too but I'd like to know if they will fit first. Thanks
Matt [img]/smile.gif[/img]
slugger_2003
<!--QuoteBegin-EY+--><div class='quotetop'>(EY)</div><div class='quotemain'><!--QuoteEBegin-->I think they would, the mounting holes are the same across the range. You would need the discs redrilling for 4 stud though.
Or go for the Regal? 308 kit, apparently it's come down in price recently.<!--QuoteEnd--></div><!--QuoteEEnd-->
It depends on the age of Calibra....some of the 16v's are already 5 stud although most are 4 admittedly.
I got the 308mm kit from LMF and think they are great. Depending on what style of disc you want, prices between £325 and £375 IIRC.
Ha, £325 for a student is a wee bitty much thanks. But thanks for the suggestion. Been looking on ebay. Is it much hassle to re-drill the discs? Are the calipers the same on a N/A redtop cally and a turbo redtop cally? Even the 284(i think?) and 288mm discs?
Could I get some confirmation on this? The saab 308mm discs and calipers (what model of saab do these come off?) and the calibra turbo 288mm discs and calipers will fit straight onto my 1994 2.0 16v Redtop Calibra? No-one here is sure if the 288mm golf/corrado vr6 discs and calipers would fit straight on?
Thanks.
Thanks.
slugger_2003
<!--QuoteBegin-slugger_2003+--><div class='quotetop'>(slugger_2003)</div><div class='quotemain'><!--QuoteEBegin-->Any reason why most people tend to use brakes from other vauxhalls? Which uprated vauxhall brakes would you suggest?<!--QuoteEnd--></div><!--QuoteEEnd-->
Because you can get larger sets and cheap from the second hand market.
slugger_2003
<a href="http://cgi.ebay.co.uk/ASTRA-GTE-GSI-CALIBRA-2-0-VECTRA-Grooved-Brake-Discs_W0QQitemZ180084992461QQihZ008QQcategoryZ41538QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/ASTRA-GTE-GSI-CALIBR...1QQcmdZViewItem</a> i'd try something like this first before spending hundreds, they'll be far better than standard without throwing you thru the screen everytime you slow down!
MJ
Users browsing this forum: Bing [Bot] and 6 guests
