What is this noise? (power steering related)
by L337 calibra » Thu Mar 01, 2007 10:21 pm
Few days ago I noticed a bit of leakage around the PAS bottle, opened it up to find nothing inside, leak was from the top hose that joins to the bottle the locknut was loose.
Around the same time as the leak I started hearing this shreiking noise.
Thinking oh I need fluid I got some, did the instructions according to Cav16 got to the bit to discharge, pumped pedal 25 times, didnt hear any whooshes but assumed it wouldnt as I thought there aint no fluid.
Opened Pas bottle to find it between Max and Min with some horrible looking <!--coloro:black--><span style="color:black"><!--/coloro-->black fluid, so where was all the fluid? BTW I was running with F19 pulled prior to this I know the 4x4 wasnt working so pulled it anyway, did all the fluid stay in the accumulator because it was techincally disconnected?<!--colorc--></span><!--/colorc-->
Anyway ive made a short vid showing the noise, usually get a small shreik on startup of the car and at each end of lock, the sterring wheel shudders a bit on lock and can hear the pump strain a bit.
Firstly im gonna have to drain the black stuff away, but heres the vid.
<a href="http://s8.photobucket.com/albums/a48/c90nutter/?action=view¤t=70f8e632.flv" target="_blank">http://s8.photobucket.com/albums/a48/c90nu...nt=70f8e632.flv</a>
Andy
L337 calibra
by Phantom » Fri Mar 02, 2007 12:59 am
where did you do the wheelspin test?? are you sure just the fronts spun? if the 4x4 isn't working the 4x4 light should be on, have you tested by starting the engine with your foot on the brake to see if the light stays on?
by L337 calibra » Fri Mar 02, 2007 1:13 am
<!--QuoteBegin-Phantom+--><div class='quotetop'>(Phantom)</div><div class='quotemain'><!--QuoteEBegin-->where did you do the wheelspin test?? are you sure just the fronts spun? if the 4x4 isn't working the 4x4 light should be on, have you tested by starting the engine with your foot on the brake to see if the light stays on?<!--QuoteEnd--></div><!--QuoteEEnd-->
Did wheelspin test at a road junction, dry road no gravel
Bulb has blown or removed, I pressed brake pedal on startup and no 4x4 light at all.
Andy
L337 calibra
by Phantom » Fri Mar 02, 2007 1:18 am
does the 4x4 light illuminate at all?
by L337 calibra » Fri Mar 02, 2007 1:21 am
<!--QuoteBegin-Phantom+--><div class='quotetop'>(Phantom)</div><div class='quotemain'><!--QuoteEBegin-->does the 4x4 light illuminate at all?<!--QuoteEnd--></div><!--QuoteEEnd-->
No
Andy
L337 calibra
by Phantom » Fri Mar 02, 2007 1:26 am
ok then with fuse 19 in place when you turn the ignition on you get no 4x4 check light?
how old is your car? cause the earlier turbo's you can read the 4x4 codes
no-one's fitted a switch anywhere have they, to switch between 4x4 and fwd
by L337 calibra » Fri Mar 02, 2007 1:35 am
Correct.
93 k.
No switches as far as ive found.
Only way to confirm is to remove clocks, which ill do over the weekend, Jeez the amount of jobs to do is piling up lol.
Andy
L337 calibra
by L337 calibra » Fri Mar 02, 2007 7:46 pm
Hmm, since I bled the system the noise seems to have stopped, steering seems a tad lighter too [img]/smile.gif[/img]
Andy
L337 calibra
by Phantom » Sat Mar 03, 2007 1:15 am
anything from the 4x4??
by L337 calibra » Sat Mar 03, 2007 9:59 pm
Well I undid the hex screw thats part of the accumulator, the guide said thats part of the 4x4 so I dunno.
Anyway a little test today shows that it probably IS working, not too sure, where I was there was a few people about so didnt want to look like a **** but I didnt get any wheelspin and that was on gravel, course the pull off wasnt as quick as it should be because of the wastegate issue.
Andy
L337 calibra
by Phantom » Sat Mar 03, 2007 11:09 pm
when the 4x4 is active you sholud get a check light on start up, perhaps the bulb has been removed afterall
by L337 calibra » Sat Mar 03, 2007 11:51 pm
Ok so now what is the best way to drain the system?,need to get rid of the black stuff and didnt get chance to do it when I was checking it over.
Andy
L337 calibra
by L337 calibra » Sun Mar 04, 2007 1:12 am
Thanks, been looking all over for a guide like that.
Andy
L337 calibra
Users browsing this forum: Bing [Bot] and 6 guests
