Rear Camber!
Rear Camber!
I lowere the back 40mm and now the wheels have noticable camber!
is there any way i can get rid of this?
PuppiesBalls
Common problem on Calibra's when they are lowered. You can either live with it and be prepared to buy new tyres alot more often with the inner edges scrubing out very quickly OR you can get camber adjusting bushes to fit to the rear wishbones. There have offset hole through them rather than centred so that as they are rotated, the camber is adjusted at the same time. It won't correct is completely however it will help.
Users browsing this forum: Bing [Bot] and 5 guests
