v6 rear brakes
v6 rear brakes
by marko » Thu Apr 05, 2007 7:56 pm
Imagethought id paint my calipers today since they looked a bit of a mess behind my new alloys, wish i hadnt started now, the pads fell to pieces as soon as i unbolted the caliper, got the disc off and the handbrake shoes did the same! disc is also had it, cant belive how many different disc sizes these cars have - should be 286mm on the rear being a 97 v6 but it only measures 270mm, vaux epc doesnt even recognise the part number stamped on the old ones - GM 90375510, anyone else had problems with disc sizes - quick tip for removing seized on discs - remove caliper and screw bolt back in, tighten it up and it pops the disc off, put something between the bolt and the disc to avoid marking the surface. Image
marko
by Mark1 » Thu Apr 05, 2007 9:18 pm
Had the same problem with mine, they are only 270 if you get the 286 the part that the handbrake shoes fit in to is to small.
Blackdiamond PT No KBC599G12 well thats what is on the box.
by marko » Thu Apr 05, 2007 9:32 pm
gonna get 270mm ones, thats what came off. Hope the handbrake shoes arent all different as well!!
marko
by Mark1 » Thu Apr 05, 2007 11:36 pm
Just some off the shelf from Halfords.
by Tim2001 » Fri Apr 06, 2007 12:24 am
Rear brakes on the v6 have always been a pain on the parts side had both wrong parts and discs before now.
Tim2001
by marko » Fri Apr 06, 2007 12:42 am
if i get the bigger discs will they fit, got to change pads and handbrake shoes anyway.
marko
by Mark1 » Fri Apr 06, 2007 12:57 am
No, the bit that handbrake goes in is not the right depth(to small).
by ash_pearce » Mon Apr 09, 2007 10:53 pm
ive got exactly the same problem, started as just replacing the handbrake shoes, now needs new discs and pads. bought some today not knowing the size issue!! why cant things ever be simple! so the correct size for the v6 should be 286? is that right?
ash_pearce
by Mark1 » Mon Apr 09, 2007 11:04 pm
<!--QuoteBegin-ash_pearce+--><div class='quotetop'>(ash_pearce)</div><div class='quotemain'><!--QuoteEBegin-->ive got exactly the same problem, started as just replacing the handbrake shoes, now needs new discs and pads. bought some today not knowing the size issue!! why cant things ever be simple! so the correct size for the v6 should be 286? is that right?<!--QuoteEnd--></div><!--QuoteEEnd-->
No you need 270mm, all mags show 286 but most seem to need 270 but check just run a tape over them.
by marko » Fri Apr 13, 2007 12:03 am
well new discs came today, got pads+handbrake shoes from autovox. the pads must be wrong as they dont cover all the disc, autovox not answering e-mails so going down motorfactors tom.Image
marko
by marko » Sat Apr 14, 2007 6:08 pm
well all finished now, got the right pads eventually no thanks to autovox!!! drivers side was a pain to do, the disc was held on by the old handbrake shoes, even after loosening the adjuster off. im quit pleased with the results.
marko
by Mark1 » Sat Apr 14, 2007 7:46 pm
Well they come up well.
by ash_pearce » Sat Apr 14, 2007 7:52 pm
looking good mate!
got my new disks today hopefully fit them tomorrow, the pads you got eventually were they listed for a v6? 2 of my local motor factors say there is only one type of pad right across the range but both were the smaller type you had.
ash_pearce
by marko » Sat Apr 14, 2007 9:06 pm
not sure what they were listed as because the missus picked em up, sent her with an old one for comparison and told her not to come back without any lol!!!!!
marko
