Caliper Guide Bolts
Caliper Guide Bolts
by Fostersice17 » Fri Apr 13, 2007 9:11 am
Hi people,gonna do my front brakes at the weekend,done the rears before but not the front,reading the "trusty" haynes manuel is states that the caliper guide bolts have gotta be torqued up,anyone know the torque setting? Or can that just be tightened up?
Fostersice17
by Fostersice17 » Fri Apr 13, 2007 2:37 pm
Just spoke to my mechanic who says just overhand tight will be ok,dont bother with the torque,saying that the last time i had my kam cover off i thought id actually use the specified torque for a change,never had before,and i found it was way to tight,either that or my torque wrench was playing up :frown:
Fostersice17
by Fostersice17 » Fri Apr 13, 2007 3:18 pm
True,i guess its just a case of not overtightning,like i said before i did not trust the torque setting for the kam cover,if i would have used the correct setting imo i would have cracked the cover.
Fostersice17
by Rusty_CallyT » Fri Apr 13, 2007 3:21 pm
i always use a torque wrench if theres a value listed, never had a problem, and brakes are certainly sommit id use it for
Rusty_CallyT
by mwcav » Sat Apr 14, 2007 9:17 am
Must admit, I didn't use a torque wrench on my guide bolts, just used common sense on the tightness. [img]/smile.gif[/img]
mwcav
by Fostersice17 » Sat Apr 14, 2007 11:22 am
<!--QuoteBegin-mwcav+--><div class='quotetop'>(mwcav)</div><div class='quotemain'><!--QuoteEBegin-->Must admit, I didn't use a torque wrench on my guide bolts, just used common sense on the tightness. [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Which is what im gonna do Cav [img]/smile.gif[/img]
Fostersice17
