Weird noise/experience
No, this isn't about the time I was laying in bed and I got abducted by aliens....
Last week, I had both my cv boots replaced and my passenger side front wheel bearing. I drove my car off from home and as I stopped this rather odd noise and feeling happened; I put on the brakes and they bit, then it felt like something slipped and gragagaga noise came and my brake pedal vibrated.
The noise/feeling doesn't happen all the time, only when braking. It feels like something is slipping and it seems to loose some brake force. Now, considering it's happened in a day and it is only intermittent, I have no idea. Brake pads don't just give up intermittently do they? (And yes I shat myself when it first happened)
My Mechanic thinks it could be a driveshaft but, he did the work in the first place and why the hell is it happening now?:sob:
Any idea's people?
Any idea's people?
Twigz
Is this when you pull off? The ABS does a test which is why it grinds. I usually maneouver with the brake on when pulling off from my house because it's a tight sqeaze getting out and I get the usual grind from the ABS and off I go.....
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
<!--QuoteBegin-se5+--><div class='quotetop'>(se5)</div><div class='quotemain'><!--QuoteEBegin-->Is this when you pull off? The ABS does a test which is why it grinds. I usually maneouver with the brake on when pulling off from my house because it's a tight sqeaze getting out and I get the usual grind from the ABS and off I go.....<!--QuoteEnd--></div><!--QuoteEEnd-->
i get that too i spent ages cleaning sensors until i didnt bother at al and now you're telling me that lol
DeepSnoozer
Well can honestly say I've never experienced that?
