cv boot
it's a pretty easy job to do yourself, just make sure you have the right tools for the job, a small hint, to undo the large castellated nut on the hub, remove your road wheel first remove the dust cap to the nut and the split pin, refit the road wheel without its center cap then you'll have the weight of the car to use when you undo the nut
Users browsing this forum: Bing [Bot] and 16 guests
