Convergence on Real Wheel, Camber on Front Wheel
I'm gutted, i found out that within a year of carefull driving i've developed a slight non worring camber on the front wheel of a 10th of a degree or so, but the most worring part is in the back with my driver's side rear wheel is opened 2 milimiters , i've looked carefully underneath and i only found the pad where i usualy put the jack to rise the car was a little bit bent (just a little bit).
The bit question is: i also know that my bearings are going, the fact that i'm on the road and i dont hear a sound but when i go over bumpy roads all hell breaks loose (lots of clinging sounds) makes me belive that the 2mm convergence is being caused by that.
What do u think mateys?
DeepSnoozer
DeepSnoozer
