whats the difference
by tommycon45 » Sun Jul 08, 2007 5:24 pm
hiya,,, after looking at the advertisements for lower springs the V6,4x4 and turbo seems to be different than the others,, i cant seem to see what that is,,
are all 4 springs different??? the front V6 seem identical to to turbos,
can anyone clear this up for me???
cheers
tommycon45
by MJ » Sun Jul 08, 2007 5:38 pm
I expect the V6 weighs more and thus the spring poundage would be adjusted accordingly
MJ
by tommycon45 » Sun Jul 08, 2007 6:15 pm
yep you got a point there,, the 4x4 will be a little heavier as well,, never thought of it that way, so you think they may be stiffer??<!--QuoteBegin-MJ+--><div class='quotetop'>(MJ)</div><div class='quotemain'><!--QuoteEBegin-->I expect the V6 weighs more and thus the spring poundage would be adjusted accordingly<!--QuoteEnd--></div><!--QuoteEEnd-->
tommycon45
by Phil » Fri Jul 27, 2007 8:59 am
I've got turbo lowering springs on my 8v!!
Holds the arches off the 18's nicely.
Phil
