Steering rack which one???
by amit710 » Tue Jul 17, 2007 9:25 pm
Hi,
Got 16v redtop 1993. Need a new steering rack but a bit confused into which one to get. I have a ZF one standard in there at the moment. Just need to know what type it is as iv seen many different ones for the car. Looking for a direct replacement. If anyone can help with like a model number or something it would be great or if not just what its called to identify the corect matching one.
Thanks
amit710
by Stupink » Tue Jul 17, 2007 9:35 pm
ZF racks arn't that great as they get older, you're better off with a GM one. If you're getting a recon rather than one out a scrappy then they should be able to advise. else do a search, the ZF/GM rack question has been posted a few times, and i think the part numbers are inluded for the gm one in at least a couple of those posts.
