rear wheel bearing (turbo)
was wondering if anyone here can help out with some info......
i have got N reg 4x4 turbo..... nsr wheel bearing has slight noise comming from it... looked part up, all calibra rear wheel bearings are the same part number, but what i am wondering is..
to change the bearing you have to unbolt the rear hub off the carrier, push out old bearing, then press in new one(part £30)... what i am wonder ing, to save myself some work, is, can i go to the breakers and use a v6 rear hub/carrier(5stud) even tho its only off a 2wd? how do the rear shafts attach onto the rear hubs? can this be done, or do i need to use an other turbo rear hub
ecosseM
