calibra turbo suspension
can anyone recommend a suspension kit for the calibra turbo. don't want coilovers. was thinking of eibach 25mm springs with bilstein shockers,with a 25mm dropwill i still need a camber correction kit?
Russ Neal
:p Nice...
I have a set of Jamex Springs 40mm lowered, uprated front shock and soon rears aswell. I get a harder ride but handles well...
Springs I had on to start with were even lower, must have at least been a 60mm drop, that was too hard, try not to go lower than 40mm, I think you might be ok with the camber with 25mm lowering springs, 40mm your just starting to wear the inner tyre a little, IMO...
I have the 2.0 8v not turbo by the way, thought I would just put some info out there...
