Lowering my Cally
Lowering my Cally
by calibra_lee » Tue Nov 13, 2007 2:29 pm
Hi everyone, i'm new on here and am going to lower my calibra.
Is there a post/thread on here that takes you through the process of lowering your car including pics?
Also what mount is it best to lower the car by as i have just bought some 17" alloys with a 45mm offset.
calibra_lee
calibra_lee
by tazz666 » Tue Nov 13, 2007 2:36 pm
hi there mate ive loward mine 40mm on 17",with 45mm offset and it runs fine and if you live near to mke i will do it for you
tazz666
by calibra_lee » Tue Nov 13, 2007 2:57 pm
tazz666 wrote:hi there mate ive loward mine 40mm on 17",with 45mm offset and it runs fine and if you live near to mke i will do it for you
cheers tazz i live in brum so i dont know how far that is from you.
Also when you buy aftermarket lowring springs does it level out the ride height as they tend to sit higher at the rear on standard springs.
calibra lee
calibra_lee
by tazz666 » Tue Nov 13, 2007 3:06 pm
im in corby northants, and i yhink it does, if you look at the post (ive done it you will see what my cali looks like on the springs
tazz666
by Calibra_Mike » Tue Nov 13, 2007 7:40 pm
40mm is pretty much what you need for 17s, any lower and its gonna become a really hard ride...
If you're wanting to do it yourself, get a haynes manual, thats what I used to do mine... ITs also worth replacing some of the other parts while you have the struts off, ie Lower suspension arms, anti-roll bar links and track rod ends...
by calibra_lee » Wed Nov 14, 2007 11:49 am
thanx for the advice guys
calibra_lee
