Fitting new wishbones
by thegeth » Tue Jan 29, 2008 7:47 pm
Was wondering if this is a job needed to be done at a garage, my stepdads got all the right tools but wasn't sure if the wishbones are an easy fit.
thegeth
by Phantom » Tue Jan 29, 2008 8:30 pm
I did mine ok just depends if you get any stubborn bolts, other than a ball joint splitter the rest of the tools you need are pretty standard
by bodgetastic » Tue Jan 29, 2008 8:47 pm
Not a difficult job, I would do it yourself, as said above hardest bit is probably splitting the ball joint :wink:
by thegeth » Tue Jan 29, 2008 8:50 pm
ok cheers for response, so is their a specialist tool for splitting the ball joint or can u find another way of doing this.
thegeth
by RobbieV » Tue Jan 29, 2008 9:01 pm
Couple of quid for a ball joint splitter from Halfords.
