Brake vibrations!
Brake vibrations!
I know this has been posted before, occaionaly when i brake regardless of weather or speed, i get a wierd vibration through the peal as if its grinding, it doesnt affect the braking and the ABS light doesnt come on! Ive have new pads fitted, might it be they were put on incorectly, they were fitted about four months ago, but car has only been doing this for about a month! Cheers!
tidders14
I have a similar problem mine almost sounded like a gear not meshing intermittantly on braking but coming from the front left side the pads are fine
, ive looked underneath behing the disk and i can see the ABS ring has shiney metal all the way round the teeth but the rest is rusty, i suspect the wheel bearing needs a look, but the weather is not all that good so ill let you know how i get on, or maybe this story rings alarm bells for someone else who would like to give some input, PLEASE LOL
Ricardoco
