Rear Crossmember
Rear Crossmember
Yep two days after getting the car back from its MOT a strage noise appeared...
Ive managed to trace to it to what seems to be the rear crossmember bracing bracket bush. Does this sound likey?
When I had a mate rock the car I noticed the sound came from where the big securing bolt. To look at it does seem like there is no rubber bush there at all, where as in the haynes manual it looks to be a lot thicker...
Anyone had this problem? Easy DIY or an arse of a job?
