steering
steering
by jonroyski » Wed Apr 09, 2008 6:16 pm
hi there. can anyone help me. at 60mph my steering wheel starts to shake. whats my problem.
jonroyski
by luke_16v » Wed Apr 09, 2008 6:19 pm
balencing? tracking?
luke_16v
by jonroyski » Wed Apr 09, 2008 6:39 pm
the tracking and balencing have both been done 2wks ago, anymore idears
jonroyski
by luke_16v » Wed Apr 09, 2008 6:58 pm
hmmm.....tried changing the suspension???
mine snatches to either side, i need new suspension,
luke_16v
by Phantom » Thu Apr 10, 2008 1:08 pm
most calibras suffer from worn suspension bushes on the lower suspension arms, quite easy to change and can be bought for around £45 for the pair, failing that it could be warped disks, worn track rod ends and in severe cases the steering rack
by jonroyski » Thu Apr 10, 2008 6:23 pm
at 75mph it tends to stop
jonroyski
by RobbieV » Thu Apr 10, 2008 10:38 pm
Do you have aftermarket alloys ?
could be spiggot rings.
by jonroyski » Fri Apr 11, 2008 7:54 pm
wot are spiggot rings robbie
jonroyski
by RobbieV » Fri Apr 11, 2008 8:08 pm
The spigot is the bit in the centre of the hub that you rest the inside centre of the wheel on whilst aligning the studs and screwing back the wheel nuts. On generic after market wheels, the spigot hole inside the wheels is a lot bigger than the spigot on the car. So what you need to do in this case is fit spigot locating rings. These are just rings of aluminium or hard plastic, that fit over the spigot on your car and then have a proper fit with the spigot hole on the wheel. If you don't have the spigot taking all the weight of the car, chances are you'll break one or more studs when you drive the car hard or have to brake hard. Remember the wheel nuts are simply there to hold the wheel on, NOT support the weight of the car. Also, as there is nothing to centre the wheel, you'll notice the wheels go in and out of balance because as you drive around, they'll move around on the hub.
by big_gordy » Sun Apr 13, 2008 1:17 am
lower suspension arms i would say i have this prob too
by cally8valver » Sun Apr 13, 2008 3:03 am
check balancing again especially if they are stick on weights on the wheels other than that bottom arms and or worn track rod ends or bottom ball joints if ball joins just change bottom arms it easier
cally8valver
