Rear wheel bearing removal
by callyse5 » Thu May 15, 2008 2:44 pm
hi anyone tell me the size of the nut at the back of the rear wheel bearing which you have to remove in order to get the hub out to change the bearing......
callyse5
by Calibra_Mike » Thu May 15, 2008 4:00 pm
If you mean the hub nut and if its the same size as the front then it will be a 30mm if its not the same then I dont know, sorry...
by callyse5 » Thu May 15, 2008 4:59 pm
Calibra_Mike wrote:If you mean the hub nut and if its the same size as the front then it will be a 30mm if its not the same then I dont know, sorry...
no its the nut at the back of the hub under a plastic cover mate you have to pop the cover off then access the nut. just below where the shocker mounts.
callyse5
by Phantom » Fri May 16, 2008 9:40 pm
the plastic cover you're referring to is the centre of the rear ABS ring, pop it off and the rear hub nut is there and should be the same as the front
