convert from 5-stud to 4 stud
by Hulmie » Sun May 25, 2008 3:47 pm
right i purchased some 19s for my old 4 stud cally but then had the accident. Now i have me new car which is 5 stud i was hoping to fit these wheels but i need to convert the car.
What parts would be needed to convert to 4-stud. I know i would have to change front disc's and hub which is fairly straight forward. But what would be needed to convert the rear and what problems would i come across and would i need to replace any brake lines/bolts/cables?
Hulmie
by RAINMAKER » Sun May 25, 2008 7:03 pm
Hulmie, are your hubs from se9 v6 as im in need of four hubs mate, if you go ahead with the four stud conversion can i have first refusal on them. pm me if you like. regards neil.
RAINMAKER
by Hulmie » Sun May 25, 2008 9:43 pm
i know the car was a v6 auto mate. so if i go ahead with the conversion then i will give you a shout.
Hulmie
by cornishtaz » Sun May 25, 2008 10:13 pm
Neil will need the 288mm disc set-up
cornishtaz
by Hulmie » Mon May 26, 2008 9:35 am
i have 308mm disc set up mate, so i will just get some 308mm 4 stud disc's
Hulmie
by cornishtaz » Mon May 26, 2008 9:36 am
what condition are your 308 disc's?
cornishtaz
by Hulmie » Mon May 26, 2008 9:41 am
good condition mate. There grooved and drilled disc's
Hulmie
by cornishtaz » Mon May 26, 2008 9:43 am
I'm looking at doing the 308 conversion would you sell them on and where is the best place to get the brackets for the calipers?
cornishtaz
by bodgetastic » Mon May 26, 2008 10:13 am
They were made 5 stud for a reason, I personally wouldn't go down the route of changing to 4 stud makes much more sense just to sell your wheels and buy 5 stud equivalent.
by p34nut » Mon May 26, 2008 1:14 pm
humlie you can buy a hub conversion kit, i will be a pian tho
ive used them before at work. eg, the pcd of an mgf is 4x95.25 and i used the conversion kit which is like a hub centric spacer with studs which i bolted to the hub and the bolts sit flush within the recess and then i placed the wheel on the spacer and used nuts to bolt it to that making the cars pcd 4x100 allowing many more wheels to be fitted.....
you can get these kits made to order for your personal aplication
you can use the same process yourself its easy but depending on the offset of your wheels you may need to send them to somewhere like autopart so they can make your wheels a lower offset allowing for the conversion kit
p34nut
by C411BRAnut » Wed May 28, 2008 1:24 pm
bodgetastic wrote:They were made 5 stud for a reason, I personally wouldn't go down the route of changing to 4 stud makes much more sense just to sell your wheels and buy 5 stud equivalent.
Agree. Seems odd to "trade down".
C411BRAnut
