Rear Shock Absorbers
by markybrisca » Sun Jun 08, 2008 8:31 pm
Hi, my SE6 just failed the MOT on a burst rear shocker, ordered 2 from Vauxhall (cheaper than any factor surprise surprise) is it as easy as removing wheel, remove bottom bolt and remove top nut in boot panel? I have sprayed both nuts/bolts in WD40 yesterday to help the job by the way!
markybrisca
Easy!!!
by markybrisca » Thu Jun 12, 2008 1:39 pm
Easy DIY job, 1 bolt holding lower mount on and 1 nut in boot side panels, rides a lot better now, more solid - well worth £60 for pair of genuine GM parts too!
markybrisca
by Phantom » Thu Jun 12, 2008 2:25 pm
not too bad but I bet you'd have saved a bit more through our trade club
by PuppiesBalls » Thu Jun 12, 2008 3:38 pm
yup i will second that, tis a peice of p**s to remove shocks,you'll have each side done in 15 mins without breaking a sweat!
PuppiesBalls
