Front passenger suspension
by Robs-se » Sun Jun 22, 2008 9:00 pm
i have GMAX Shocks, lowered 40mm on 215 x 45 x 17 rims
problem is when i go over speed bumps, dips in the road etc it scrubs the front passenger tyre on the arch. there is noticable wear on the outer edge of the tyre where this has been happening.
There is a gap of about 1.5 fingers between the top of the tyre and the wheel arch on the passenger side and 2 fingers on the drivers side.
Have tried the bounce test on that side to see if the shocks failed but that appears ok. only thing i can think of is the strut leg is coming through the doughnut at the top.
Anyone anything else they can advise on looking for.
Rob
by RAINMAKER » Sun Jun 22, 2008 9:19 pm
mate have you checked the drop link bushes and arb bushes
RAINMAKER
by Robs-se » Sun Jun 22, 2008 9:27 pm
Good point, will have a nosey
Rob
by Fraz » Sun Jun 22, 2008 9:31 pm
got mine lowered but tyres are 215/40/17 had the 45's on once and got the same problem
by RAINMAKER » Sun Jun 22, 2008 9:36 pm
my drop link had snapped on the drivers side and it rubbed on the passenger side over humps etc replaced and no probs after
RAINMAKER
by Robs-se » Sun Jun 22, 2008 9:42 pm
Fraz wrote:got mine lowered but tyres are 215/40/17 had the 45's on once and got the same problem
Would putting 40's on not affect the running ie speedo etc or not make any difference
Rob
by Fraz » Sun Jun 22, 2008 9:49 pm
Robs-se wrote:Would putting 40's on not affect the running ie speedo etc or not make any difference
Rob
yup it will....be more accurate :D
http://www.jason.burgess.btinternet.co.uk/tyre_size.htm
Users browsing this forum: Google [Bot] and 7 guests
