Help getting my calipers off? :) - Sorted!
by DC 12v » Tue Sep 02, 2008 1:56 pm
A link to the how-to would be fantastic, I've been browsing all morning..
The wheels off, just can't remember how to remove the calipers!
Thanks
Jay
DC 12v
by Fraz » Tue Sep 02, 2008 2:04 pm
front or rear?
by DC 12v » Tue Sep 02, 2008 2:10 pm
Oh, sorry. Fronts
DC 12v
by Callyman » Tue Sep 02, 2008 2:19 pm
To remove them complete, you need the remove the two bolts that go into the hub, they are 17mm iirc. to split them (to change pads etc) you need to pop out the plastic caps and use a hex key, which i think is either 7 or 9 mm.
by DC 12v » Tue Sep 02, 2008 2:27 pm
That will do! Thanks - I'll get right on it!
DC 12v
by Callyman » Tue Sep 02, 2008 2:56 pm
You're right, i remember it is a 10mm allen key onto the hub.
by vinny_69 » Tue Sep 02, 2008 3:12 pm
still haven't got yourself a haynes book then dc :-k
vinny_69
by DC 12v » Tue Sep 02, 2008 3:13 pm
Shut up! :P I've managed without it so far! ;)
DC 12v
by vinny_69 » Tue Sep 02, 2008 3:16 pm
DC 12v wrote:Shut up! :P
:shock: bit harsh
i was only asking :roll: i bought one the other day you would not believe the amount of info you get out of it.
vinny_69
by DC 12v » Tue Sep 02, 2008 3:28 pm
It was said in jest vinny! :) Didn't mean to offend :)
I'm downloading an electronic haynes today ;)
DC 12v
by vinny_69 » Tue Sep 02, 2008 3:32 pm
not much good when your by the side of the road is it :lol:
(unless it's on yer laptop :-k )
you should respect your elders SON :alright:
now we are quits.
vinny_69
by DC 12v » Tue Sep 02, 2008 3:38 pm
Touche! :P
Laptop indeed, always with me. ;)
When i'm by the side of the road, my trusty friends at AA, who know me personally now, take care of the problem lol!
DC 12v
by DC 12v » Tue Sep 02, 2008 8:56 pm
What a complete fail tonight!!
Got the caliper off after 2 hours of searching for a size 10 alan key - Great.
Changed the disk - Fantastic.
Now when changing disks, I remembered someone telling me the blocks have to be changed also, no matter how good a condition they look to be in as they are most likely out of shape after warped disks.
I remembered this after removing the whole caliper, and couldn't put the caliper back onto the new disk as there was no room! - Tried pushing them apart to no avail..
It continues...
Looking for a 7mm, there most certainly is not one here... so I go off to the old dear next door who I was certain had a full alan set.
No 7mm there either!
Back home, I grab an 8mm and a grinder.. whoops, over ground it.
Before hanging myself on the conveniently placed rope I decided I'd call it a night and get everything sorted tomorrow..
Popped out one of the blocks and refitted the caliper loosely, then bolted the wheel on and let the jack down..
And what have I accomplished?
A sign that made everyone laugh when they saw it....
This is why I don't dare to tackle an engine issue :(
DC 12v
by Fraz » Tue Sep 02, 2008 9:07 pm
first rule...make sure you have the right tools for the job before starting
as for the new pads you should always fit new pads with new disc's, to get the piston back in the calliper, fit the old pad to the outside, refit the carrier ..then use a bar to push the piston back ..or use a large clamp if you have one (can do that without fitting the calliper back on)
by DC 12v » Tue Sep 02, 2008 9:12 pm
I bought a full alan set just a few months back, but some glutton for punishment has used it and not returned the tools!
Damn, thought I was ready to do what should have only been an hours job!
Thankyou for the piston advice, I'll have a go at that tomorrow.
DC 12v
