Knock, knock,knocking top of suspension
Having read the posts on suspension knocking I located mine as coming from top of passenger side suspension... either mounting or shock absorber.. but drivers side does not knock and its top nuts must be tightened to at leat 80 ft lbs...(my 15/16 fits nicely).. knocking passenger side is set to specified 41ft lbs ... any risks if I tighten the passenger side nuts to 80 ft lbs before I start thinking about replacement parts.
Also does anyone have an exploded digram of the top suspension mounting they can post...Haynes is less than ideal..
Hopefully thanks in advance..
kdchorse2
the first nut is tightened to 55nm and the second nut is tightened to 200nm
take off the top nut and ring and tighten the first nut to the required torque and then replace the ring and second nut tighten to required torque..
if you believe the strut to still knock then suspect the strut bearing to be worn and replace..
RAINMAKER
You could try the large ring nut that holds the cartridge into the holder. mine used to knock until i tightened it. Its a 55mm so i used a wrench on mine. Try it, it may save you torquing a nut up too tight and snapping it
Re: Knock, knock,knocking top of suspension
kdchorse2 wrote:Also does anyone have an exploded digram of the top suspension mounting they can post...
Robs-se wrote:Try it, it may save you torquing a nut up too tight and snapping it
Well if he snaps the damper rod by doing it up too tight, I ain't telling him he's done it wrong....
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Users browsing this forum: No registered users and 106 guests
