Wishbone quickie
Wishbone quickie
If giving the bolts a quick tweak to tighten is it best to have the wheel off the ground
or can it be done standing?
Re: Wishbone quickie
make sure you use quality tools,un like someone
if you run into any bother supertyres dunstable road did my pass side for 30 squid
vinny_69
Why, what happened to you? When the mechanic did my right side one the pillock took out the rear bolt, then decided to reverse the car and wore away the inner lip on the bumper and liner, twot
As with most bushed suspension components its BETTER to tighten them ON the ground in the resting position to prolong bush life.
Robs-se wrote:Why, what happened to you? When the mechanic did my right side one the pillock took out the rear bolt, then decided to reverse the car and wore away the inner lip on the bumper and liner, twot
the big 16mm nut was done up so tight i went through most of my tools trying to get the fecker off and in the end gave up
vinny_69
vinny_69 wrote:Robs-se wrote:Why, what happened to you? When the mechanic did my right side one the pillock took out the rear bolt, then decided to reverse the car and wore away the inner lip on the bumper and liner, twot
Been there myself, trashed many a ratchet, spanner socket, screw driver
impact socket and 3ft power bar always works
or breaks captive nut ooopppssss
Already broken the captive nut, the thread got screwed so had to punch a hole in the floor and use a longer bolt and self locking nut
bit of a sh!tty job as well
I find a blow torch sorts out nuts/bolts that wont budge...
i was lucky enough to only have to pay for the off side to be done
the bloke who smacked me car the other month paid for the otherside
vinny_69
