Calibra LE shocks
Calibra LE shocks
just want to double check before replacing my leg! are Calibra LE shocks the same as normal turbo shocks, as i know the LE has immisher springs!
rich_DTM
Re: Calibra LE shocks
does it still have the original spring??
yes but no. The springs on the front are not the ones which came on the car but the last owner got a replacment set from vauxhall which are red and have immisher printed on them, but i need to know about the shocks not the springs.
rich_DTM
The LE uses specific Bilstein shocks P/N are:
Front 2403004
Rear 2704003
Irmscher UK should be able to get them for you. But I expect then to be dear or NLS.
Cheers,
Tommyo.
Front 2403004
Rear 2704003
Cheers,
Tommyo.
cheers i dont need a new one just needed to know if i had to swap it over as i'm replacing a damaged suspension leg on my LE
rich_DTM
Hi Rich
My le turbo came with irmscher shocks and springs from factory..
Both the springs and shocks were red in colour and have the irmscher part number on them..
I was led to believe that all the le turbos had these fitted as a part of the limited edition profile//
Mine is still as factory set and all springs and shocks are red irmscher ones..
Can find the part numbers of mine if it helps8)
Users browsing this forum: Bing [Bot] and 19 guests
