Suspected Brake Binding
I changed the front discs on my car at the weekend and noticed when i got home from my 30 miles motorway journey home that my drivers side disc was ridiculously hot. To the point where my alloy wheel was also hot.
I also noticed that when braking the car was pulling to the left. I assume this is because the right hand side brakes have overheated.
I've only changed the discs. Not touched pads or fluid so what can be causing the issue and how do i solve it?
Thanks
Thanks
Fenix
Re: Suspected Brake Binding
discs but not pads
when you fitted the discs did you push the piston back into the caliper?
did you remember to unscrew fluid cap, if not chances are you have blown a seal or a seized piston
vinny_69
Hi
Yeah pushed the piston back and opened the cap on the brake fluid resevoir before i did.
Odd as there was no sign of binding before i changed the discs.
Fenix
i used to do it like that,been doing it like that for years
but lastime i did it under the watchfull eye of my teacher i got a slap
but if you force the piston back there is more chance of fecking the seal.
vinny_69
you have to remember that when you are forcing the piston back it is pushing the seals in the oppisite direction that the were intended to work , and therfore pushing them out of there seats that is what i have been lead to believe,
tazz666
Ive been changing my own pads and countless other cars for many people from a mini to a BMW and ive never damaged a caliper by pushing the piston in. But i've always loosend the reservoir cap.
i always loosen the cap but that only becuase im a weakling
callyman wrote:Ive been changing my own pads and countless other cars for many people from a mini to a BMW and ive never damaged a caliper by pushing the piston in. But i've always loosend the reservoir cap.
its not the caliper that can get damaged it is the seals in the master cylinder you have to watch out for:D
tazz666
i honestly not sure mate , but i did ask a technition and that is what i was told so thats what i do , and its better to be safe than sorry
tazz666
Well turned out to be a completely seized caliper. Now replaced and new pads in
Fenix
