Best option to lower between 80mm and 100mm
by Joker » Mon Apr 20, 2009 6:19 pm
I've been looking around at shocks springs, coil-overs for my calibra as I'm wanting to lower it extremely...
The lowest spring set ive seen is 70f and 50r,
What would you suggest for such a big drop? I know camber will be well out but thats not a problem I'm worrying about.
I've thought about just buying shortened shocks and just buying 80mm springs, but don't no who sells just those that I want.
Any ideas?
Joker
Joker
Re: Best option to lower between 80mm and 100mm
by RAINMAKER » Mon Apr 20, 2009 6:58 pm
IMO if your serious then i would suggest air suspension...to give you an idea have a look here...http://www.accuairsuspension.com/?gclid ... nAod6UC4QQ
RAINMAKER
by v6 steve » Mon Apr 20, 2009 8:35 pm
for that kind of drop the only way would be air suspension as rainmaker has said if you want to be able to drive it, would look well good so go for it
by Joker » Mon Apr 20, 2009 10:28 pm
yeaaaah u can drive it with it that low! Air supension is pants!! Only really good for show cars, mine isn't a show car.
I no a mate who has air ride on his car, the handling is absolute pants! It's good in a way for getting it that low! but well out my budget and not good handling so its out the question.
I think I'm just gunna get shortened shocks and 80mm springs and strap them in, I've seen that done 2. Just give it a shot! I've seen a cally lowered 100mm all round and it was sick!!! it was at pvs last year for sale!
nice one for the idea though!
Joker
Joker
by Callyman » Mon Apr 20, 2009 10:50 pm
Why isnt the Camber a problem for you?
by Mark1 » Tue Apr 21, 2009 12:00 am
That was vic-dub's car and the wheelarchs had a lot of work dune to them to make the wheels fit.
by Phil69 » Tue Apr 21, 2009 1:12 am
Not only will you need serious arch work but the rear bump stops are likely to be in contact by then...if you can find springs that dont have their coils completely compressed against each other first.
If your serious about it then dont expect to only need different springs/shocks. More work will be needed than just that.
by Joker » Tue Apr 21, 2009 8:02 pm
I'm just gauging at the minute, I would like it that low but I'm not gunna modify my arches.
Just wanted to no if anyone has done it, with out major work.
Camber isn't a problem as it's low milage
Joker
Joker
by RAINMAKER » Tue Apr 21, 2009 8:28 pm
Joker wrote:I'm just gauging at the minute, I would like it that low but I'm not gunna modify my arches.
Joker
Just picking up on your above comment joker why is it not a problem for camber as its low mileage, at the level your asking wether you can lower the cally to will put you camber out by around 5deg so the stress on joints and bushes will be very extreme not to mention the excessive wear on the tyres also..youll be riding on a very limited contact patch ie just the inner edge of your tyre..
I acept your gauging at the minute, but consider the potential hazard of poor handling and the danger of this when driving..
I only mention this as I recently had a rear suspension issue on my current car and drove around 1000 miles with fault not aware the rear camber was out as far as it was, 1000 miles later and my tyres were shot on the inside edge..
RAINMAKER
by Joker » Wed Apr 22, 2009 8:38 pm
Yeah it sort of makes sense that going that low would cause problems, how did vic dub get around it? Other than the arch work needed.
Joker
Joker
by Mark1 » Wed Apr 22, 2009 8:42 pm
I think he had some springs made but who made them I dont know.
by BazV6er » Wed Apr 22, 2009 8:53 pm
recently i had to drop mine as a spring broke and even 40mm is a good drop , but people have dropped 60mm but surely anything above that will be crazy ispecially for speedhumps,etc
by Joker » Sat Apr 25, 2009 6:08 pm
yeah but the look of it is siiik!
It ain't low enough til its on the floor IMO
Joker
Joker
by superfox233 » Sat Apr 25, 2009 10:34 pm
oh dear!!! :roll: sick maaaate!! lol!! put a donk on it!!
superfox233
by Allys Cally » Sun Apr 26, 2009 9:58 am
if you sant it sitting on the floor i'll have a word with my mate v6 steve, he has the very tool for the job :twisted:
