drive shaft/cv boot
drive shaft/cv boot
last time me and Tazz removed the d/s drive shaft the boot was weeping nothing special really
now its gushing
easy enough to replace,but would it be worth it in the long run to replace the drive shaft too?
can you get a spanking new shaft with cv and boot all in ?
one more question can you replace the abs jobbys without replacing the joint?
vinny_69
Re: drive shaft/cv boot
so i take it they dont go very often then?
had a little looky around and its either 6 squid for a boot or 60 squid each side (shaft,cv and new abs rings)
vinny_69
need to do something to my boot as well mate, the small neck has slipped down and thrown a load od grease on the inside of the wheel arch. Need to get some more grease and and new cable tie and this time put it on tighter.
the kitt i had a look at came with grease boot and the metal thingys
i think one shall give em a go the weekend
vinny_69
Good luck, can the grease be brought separatly or only in the kits?
you can buy it seperately at most motorfactors, just ask for cv grease.
Thanks guys, something for me to do on my days off next week
i know its an old thread but ive only just got round to doing it
replaced my drivers side cv boot saturday
easy peasy only problem i have now is my break pedal travels a long long way down till i start slowing,i have no idea why as i never took the caliper off so im just gonna bleed it tomorrow and see if that fixes anything
vinny_69
Have now got a tube of grease, how easy will it be to get the grease in with the boot still in place. Thinking of using a pointy thing like from glue tubes and putting it under the end of the boot and squirting in a bit at a time. Anyone any other ideas?
thanks
vinny_69 wrote:don't forget if you need a hand
You'll certainly hear me shouting, now your an expert, cheers
it's not rocket science Rob i even did the old mans inner and outer on his corsa C
vinny_69
