Brake Wear Sensors.
Brake Wear Sensors.
Anyone know if the sensors are generic across the range or is there a specific one for the V6.
Everywhere I've looked only mentions the 2.0
Re: Brake Wear Sensors.
Cut the connector off the sensor and join the wires together and tie up out of the way, saves a lot of aggro and i prefer to visually inspect the brakes
i agree with robbieV, visual inspection is much safer for me
If it's not broke, fix it until it is...........
Mine are tied up out the way, but then i have non standard brake set up on mine
