Help!! Ball joint issues!
by Crazychick » Sun Jun 28, 2009 2:44 pm
Hi folks. Just in the middle of lowering the cally, only, we've hit a brick wall! How on earth do u get the ball joints apart without mullering them??? Have ball joint splitters, but there just not budging! Even when their apart, the bottom ball joints, can't get the splitter on them! HELP!! Any hints/tips people???
Cheers....
Crazychick
Re: Help!! Ball joint issues!
by bodgetastic » Sun Jun 28, 2009 2:54 pm
I assume you have taken the nut off the bottom. Certain ball joint splitters can damage them but it sounds like a case of giving them a good clout, they will come eventually
by Crazychick » Sun Jun 28, 2009 3:03 pm
Yeah, bottom nut is off....been clouting it like mad, and still it won't shift!
How do u get the bottom ball joint off then?? Cant get the splitter on it.. :(
Crazychick
by vinny_69 » Sun Jun 28, 2009 5:02 pm
a big bar between the drive shaft and lower arm and a hammer :D thats how Unkle Damo taught me :D
vinny_69
by Crazychick » Sun Jun 28, 2009 5:32 pm
vinny_69 wrote:a big bar between the drive shaft and lower arm and a hammer :D thats how Unkle Damo taught me :D
Yep, sussed that....brute force and ignorance! Now, how do u get the damn shock cartridge out! ?????
Crazychick
by vinny_69 » Sun Jun 28, 2009 6:35 pm
much the same mate at the top of the cartridge there is a round cover nut type thing,both of mine were stuck solid,so you get your hammer and chisel and try and knock it left
(lefyt loosie rightie tighty) it helps if you have some new cover nuts as the old ones are gonna get fecked.any more questions?
vinny_69
by Crazychick » Sun Jun 28, 2009 7:42 pm
Cheers Vinny. We have finally admitted defeat for today. 8hrs solid on it has taken it's toll....my hands are killing, and I have lost the will to live at the mo :D
Shall have another go tomorrow....
Crazychick
by Fraz » Sun Jun 28, 2009 7:44 pm
I would never leaver off the drive shaft ...thats asking for trouble
the top nut will come of the strut if you have a vice or a workmate and a very large pair of stilsons (or a spanner) thats once you have stripped the strut of the springs of course
by Mark1 » Sun Jun 28, 2009 7:44 pm
If you need help I'll send Toby, about time the little sod did some work :)
by v6 steve » Sun Jun 28, 2009 7:49 pm
your new shocks should come with new nuts i put mine in the in the vice and turnned the shock
by Crazychick » Sun Jun 28, 2009 7:54 pm
v6 steve wrote:your new shocks should come with new nuts i put mine in the in the vice and turnned the shock
Now, there's an idea!! Nice one!
Thanks guy's....
Mark, prime Toby, cause he may well be needed!! :D
Crazychick
