knocking after new shocks fitted?
What could cause knocking after new shocks have been fitted??
I had a full set of new Bilstein shocks fitted to my car by my garage, and since they were fitted there has been a rattley knocking from what sounds like the area of the rear top mounts...the driver side sounds worse than the passenger side too.
I have checked and eliminated every other possibility such as loose trim, anything in cubbies in boot, parcel shelf, rear seat latches, rear seat belt upper mountings, hatch not sitting right, even had the rear interior side panels off today to see if it might be the speakers rattling, but no, nothing is loose.
I had my garage check the rear suspension bushes when it was last in to see if it could be any of them, but they said it all looks ok...I didnt really want to tell them its been doing it ever since the shocks were fitted incase it was something else.
Has anyone any idea what could cause this?, ive only ever known shocks to knock when they are fecked, not brand new....all i can think is maybe the lower top mount has 'gone'.....these feckers:
Re: knocking after new shocks fitted?
how long ago where they fitted might be the sprinds reseating themselfs
v6 steve wrote:how long ago where they fitted might be the springs reseating themselfs
About 6 months or there abouts.
i had my front shocks replaced then at around six months later it started to knock usually when full lock is applied or turning the wheel when stationary - mot had an advisary of slight movement on top bushes - so will replace the bearings at the same time
v6man54deg
after 6 months i wouldnt think it will be the spring reseatting have you checked the subfame bushes?
they never fitted them right
v6 steve wrote:after 6 months i wouldnt think it will be the spring reseatting have you checked the subfame bushes?
Yeah they checked all bushes, subframe, anti-roll bar, trailing arms...all ok.
Fraz wrote:they never fitted them right
How is it possible to fit rear shocks incorrectly??
does it do it only when driving or when u jump on the bk end ? try pushing down on the bk and see if it still bangs if it does get underneath and av a look while sum1 else is pushing down on it
Reason: Big Dan, text talk is not needed on the forum as you are allowed up to 60000 characters :)
BIG DAN
MadOnVaux! wrote:Fraz wrote:they never fitted them right
they have Bush's at the top, two one under the point at which they go through the bodywork and one on top with a washer before and after the bush, you then have to tighten them to compress the bush. they are also shaped , if they have not put the washer on or not tightened correctly then they will knock
its easy enough take them off and have a look yourself
BIG DAN wrote:does it do it only when driving or when u jump on the bk end ? try pushing down on the bk and see if it still bangs if it does get underneath and av a look while sum1 else is pushing down on it
Looks to be only when driving...I've pushed the back end down on both sides and can't hear anything.
Thing is, they are a very competent garage, and in all honesty rear shocks are pretty easy to fit, i can't see how they would manage to fit them incorrectly?
There is the two washers and compressed bush at the top (inside the cubbys in the boot)....so that brings me back to my thoughts of the lower rubber bush thing being knackered, as in the picture.
Sorted this this morning....bought and fitted two new lower mounting rubbers at the top mounting, took it for a spin, no more knocking
The old bushes were split and perished which wont have helped, (More than likely been in since the car was new) plus the metal insert for the bush was also quite free to move about within the bush, also not a great thing, so its all sorted now.......its the little things that make a big difference LOL....no more sodding annoying B*ST@RD knocking too
The knocking is back...
It was actually back the day after i fitted the new lower top mounts.....might just have been psycological that it went away actually...hmm.
I removed the upper top mounts again yesterday for a look at what might be going on and couldnt see any problems, they dont seem to move when im driving along....and its definitely worse on the drivers side.
So any other ideas what it might be?....I can only see it being a bush or something really, but garage says all are ok.....can a bush that appears OK and looks OK still cause knocking if its warn
MOT tomorrow so we'll se if that throws anything up.
